Prusa setup for a total dummy
Avatar
By snake1966 19 April 2017 15:05
Member · 1 comments
Hi
In the high expectation of receiving my Duet Wifi and 5" panel, can somebody please indicate the path to some sort of guide to setup the system for a prusa i3 type printer, I am a total noob and dummy on this, so any and all help is most appreciated.
Thanks to all in advance and best regards.
Avatar
By whosrdaddy 19 April 2017 18:17
Member · 2 comments
The wiki on this site is quite complete and provides a good starting point.
On the SD card you can find an example configuration for an i3 (cartesian) printer type, more info can be found here: https://duet3d.com/wiki/SD_card_folder_structure
Avatar
By darookee 19 April 2017 21:37
Member · 50 comments
I converted my Wanhao Duplicator i3 and wrote a small guide you can find here: https://github.com/darookee/wanhaoi3-duetwifi
Avatar
By T3P3Tony 20 April 2017 10:52
Administrator · 789 comments
Darokee, thanks for the writeup. I have added a link to it under the tutorial section of the wiki:
https://duet3d.com/wiki/Tutorials#Setup
Duet Wifi Hardware Designer
www.think3dprint3d.com
